SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
SOURCE: tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
SOURCE: timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.
Hope it may help you;
Regards,
VOTIT
SOURCE: TV won't turn on, delay/timer light flashing
Please update this with the blink count. That will indicate the circuit in which a problem was found. Once I have that information I should be able to give you the probable cause and remedy.
Dan
SOURCE: LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
1 Press the ON/STAND-BY button to turn the power on.
2 Press and hold the CLOCK/TIMER button.
3 Within 10 seconds, press the or button
to select "ONCE" or "DAILY", and press the MEMORY
button. Set the clock to the correct time if "ONCE" or
"DAILY" does not appear.
4 Within 10 seconds, press the or button to select
"ONCE SET" or "DAILY SET", and press the MEMORY
button.
5 To adjust the hour, press the or button and then
press the MEMORY button.
6 To adjust the minutes, press the or button and
then press the MEMORY button.
7 Set the time to fi nish as in steps 5 and 6 above.
8 To select the timer playback source (CD, TUNER, USB,
iPhone/iPod, TAPE or AUDIO IN), press the or
button. Press the MEMORY button.
When you select the tuner, select a station by pressing
the or button, and then press the MEMORY
button. If a station has not been programmed, "NO
PRESET" will be displayed and timer setting will be
canceled.
9 Adjust the volume using the VOLUME control, and then
press the MEMORY button. Do not turn the volume up
too high.
10 Press the ON/STAND-BY button to enter the power
stand-by mode. The "TIMER" indicator lights up and
the unit is ready for timer playback.
11 When the preset time is reached, playback will start.
The volume will increase gradually until it reaches the
preset volume. The "?" or "DAILY" indicator will blink
during timer playback.
12 When the timer end time is reached, the system will
enter the power stand-by mode automatically.
Once timer:
The timer will be canceled.
Daily timer:
The timer operates at the same time every day. It
will continue until the daily timer setting is canceled.
Cancel the daily timer when it is not in use.
