Question about JVC KD-G210 CD Player
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the right combination of buttons to take it off standby. This is a JVC DISC audio system - Model FS1000GR - single disc CD player with raido & clock
Anonymous
    Problem Solver:
  • 9 Answers
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
set.)
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
level.
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
played.
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Posted on Oct 31, 2009
Testimonial: "Took a few minutes to understand the icons or buttons but I think I've got it. Thank you so much. Enjoy your day!"
How can I disarm the Alarm. I bought my 97 Cabrio used (it didn't come with the remote) The Door locks also don't work. I can't drive it because when I turn the key the alarm goes off and it...
If you don't have the remote then its pretty much useless. I have seen at Pep Boys where they sell replacements for the factory/dealer installed alarms. Or just remove the alarm completely and reconnect everything the way it was.
Without knowing what brand alarm it is a person cannot honestly answer how to disarm it as they all work differently.
If you know a brand and model you may be able to find downloadable instruction on the manufactures web site.
Sep 08, 2011 | 1997 Volkswagen Cabrio
Bought Armitron #456974 and came without instructions
Simplest way is to use the instruction book that should have come with this watch. If you can't do it yourself, take it to a watch or jewellery store and ask them to do it for you.
Aug 21, 2009 | Bulova Watch
My car won't start be cause the alarm sounds as soon as i turn ke
I have a 95 camry 2.2 and it did the same thing. i helped jump a buddy's car then the horn started sounding. so i called the parts service for toyota they told me theres a switch under your dash, on the floor board, right above where the left is placed. there was a switch, he told me to flip it then my car started working no problem. that was about 1 yr 1/2 ago.
Aug 06, 2009 | 1995 Toyota Camry
1995 Buick Riviera SC: traction and the security light
traction switch is located next to drivers left knee on bottom of dash....you should be able to turn off the traction light there by just turning on the traction control.....the security light is telling you that there is a problem with your security system....could just need a new key with a new computer chip....make sure the key is clean and dry when using so it can read the chip....the security light comes on whenever your start the car and stays on for approximatley 2 minutes and then should go out....it is just a reminder....try this and see if it works....lock the door using the power switch on door.....close door and see if the security light comes on....watch and it should go out after about 2 minutes...if it does then your alarm is activated and working....to disarm you need to unlock the driver door with the key...anything else will set the alarm off and the lights will start flashing and the horn honking...after you set the alarm off you will always have to use the key to unlock the drivers door to turn off the alarm and reset the security system.
Jul 30, 2009 | 1995 Buick Riviera
Turns itself off within 2 seconds of being started
Lock all doors and open with key in passenger side door.Then start it..That should reset the security system>>>Hope this helps you and have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 05, 2009 | 1995 Jeep Grand Cherokee
Dash reads start disabled;due to theft sysytems;wait three minut
did you replace the fuse.if so try to get the alarm reset location,it could be in the stupidist place like my pathfinder you have to put the key in the tailgate and turn it to glass side and hold it for 20 seconds.and then hit the hidden reset switch under the rear carpet.
Feb 26, 2009 | 1995 Cadillac Eldorado
2003 Hyundai XG 350 will not start
Hooked new battery up, alarm went off, waited until it stopped, locked car with fob then unlocked and the car started.
Dec 15, 2008 | 2002 Hyundai XG350
JVC KD-G210 CD Player Logo
151 people viewed this question
Top JVC Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
