GPS Logo
Kenneth Paget Posted on Jan 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i get off simulation mode
Have no manual but guess i can try teaching myself if i get off simulation mode for a start
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • GPS Master 102,366 Answers
  • Posted on Jan 23, 2013
GPS Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444099
Points
622693
What make and model GPS device?
I what to know how to input simulation program to clear maintanance code CA on Mx2610 sharp copier
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
HOW CAN i CLEAR h4?
OR
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
How do clear H4 error code on Sharp Copier arm256
OR
H-400 error on Sharp 165
OR
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Have Sharp - AR-5516 and H5 error blinking on the screen
OR
Error h4 on sharp at m318 copier
OR
2helpful
How can I delete the Memory of RESENDFAX for MX-2310?
Try this while you're at it.
# * C * to enter the simulation mode.
Simulation 66-10 is the image memory clear which clears the print/scan/fax memory. DO NOT EXECUTE AND OTHER SORT OF CLEARS IN THE MENU.
Copier Collin Houston TX Copier and Imaging Expert
How to activate simulation mode mx-m264n
OR
When the
How to reset the Maintenance indicator sign in SHARP AR 5618
OR
When the
4answers
Could you tell me how can i enter the simulation mode for the kyocera 1815 copier.
I would suggest you check the manual of the kyocera 1815 copier. this should be stated clearly on the user manual. so check the user manual for the information as regards this.
Take care.
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
