Sony SNC-RZ50N Network Camera Logo
Posted on Jan 27, 2009
SNC-RZ50N default IP settings
Can you tell me how to reset my SNC-RZ50N to factory? I can't log onto the unit and i can't recall the default IP address/username/password.
Thanks
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Aug 23, 2009
SOURCE: how to reset to Default settings
turn on the camera, pressed holding the reset button.
Cannot recall password on my router
In most cases, you will have to reset your router to gain access. Before you do, look up the router's default password through Google and make a note of it. Most routers have a recessed reset button on the back of the unit. By pressing and holding this button for 10 seconds, the router will return to factory-default settings. At this point, you should be able to log into it using the default IP and password.
I have a Sony SNC-RZ50N that wont work
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' [email protected] ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
2answers
Hi am having prob on setting my WI-FI i forgot the WI-FI/WPA Key
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
2helpful
I cant log onto the web site or ip 192 thing to change my password,i cant remember my password and want to change it, but the site is always down or an empty page.... why cant they just make these things...
Here is the procedure to reset the system to factory default:
To use the restore settings button:
1. Locate the restore factory settings button on the rear panel of the router.
2. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings
button for about 5 seconds, until the Power light begins to blink.
3. Release the restore factory settings button, and wait for the router to restart, and for the Power
light to stop blinking and become solid green.
The factory default settings will be restored so that you can access the router from your Web
browser using the factory defaults.
Here is the link to download the manual.
Best of luck, Jim
I am unable to recall my security password.
Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1).
Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen.
Step 3. You can view the Wireless key that has been set for your Network.
Step 4. If your Router login name and password is lost, you can reset the Router to factory settings and configure the Router again.
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
2helpful
How to reset to Default settings
Connects to the explorer BUT NOT IN MSN!!!!
you need to log onto your router
typically browse to http://192.168.2.1
then go to the firewall section of your device you are intrested in the client IP filter section.
Basically remove the filters that you have inplace for complete freedom.
if you can't rememeber the logon details you will need to reset the unit to factory default settings and set the unit up again from scratch, make sure that you know your ISP log on details before you reset the unit though!! ;).
DES-3226L A1
Log in to the switch as an administrative user (using the login command).
You can type the following command:
reset {config|system}
If you type "reset config" all of the factory default settings are restored on the switch except for the IP address, user
accounts, and the switch history log.
If you type "reset system" all of the factory default settings are restored on the switch.
If you just type "reset" by itself, the switch’s current IP address, user accounts, and switch history log are retained. All other
parameters are restored to their factory default settings.
There are two ways to reset the unit back to the factory default settings. Through the web-based interface: Step 1: Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click on the System Tools tab and go to the Load Default Settings tab on the left. Step 3: Click on the Start button to proceed. This will now load the unit back to factory settings. Note: The Device IP Address will be reset to 192.168.0.1 after loading the default settings. Perform a hard reset: Step 1: Power the unit off by unplugging its power adapter (from the unit, not the wall). Step 2: Insert a paper clip into the reset pinhole. Press and hold the reset button with light pressure. Step 3: Power the device back on by plugging it in. Continue to hold the reset button. Step 4: Watch the lights on the front of the gateway. The status light and wireless light will power off. Once both lights are powered off release the reset button. Step 5: The unit will reboot and now will be reset to default settings.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
