Replaced the drive belt awhile back and put a new shaft that drives the pulley for the belt .does the spring on the pulley need to be adjusted to help turn the shaft
SOURCE: husqvarna yth2448 riding mower
you probably need to adjust the tension. if you look somwhere near the drive belt then you see a spring. tighten the spring to tighten the belt.
SOURCE: bobcat 753 skidsteer right drive control is jerky
check and, clean the hydrolic directional combination valve screens; dirt in the lines causes this
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
SOURCE: I need to replace a drive belt on a personal pace
put the belt on the engine drive shaft first the start it on the other pulley (watch your fingers so you don't pinch them) and turn it by hand clockwise and it should roll right on.
