Have you checked the fuse box for blown fuses?
The fused items you are speaking of have the lowest rated fuses in the panel. Usually 10A... and are more susceptible to failure.
Additional questions are welcome.
Thank you for using FixYa - A FixYa rating is appreciated!!
I had teh same thing happen, I jumped the car with the cables on the wrong post and now my radio will not work...I have 2007 kia Rio....the fuses are fine...any suggestions?I had teh same thing happen, I jumped the car with the cables on the wrong post and now my radio will not work...I have 2007 kia Rio....the fuses are fine...any suggestions?
You can't post conmments that contain an email address.
The first thing I would do is disconnect the battery, both terminals, and let the whole system discharge 15-20 minutes or more. Then reconnect using the correct terminals and see where you are. If it doesn't help, it will need to go to the shop to track down what may have fried.
If it happened after jumping car than Yes look in the main fuse box under the hood and check all fuses there, you may need a volt ohm meter to check some of them...
OK THE PROBLEM HERE IS IF YOU REMOVE THE MEMORY FUSE YOUR CLOCK RADIO AND INTERIOR LIGNT WILL NOT WORK. BUT IF YOU CHANGE IT(IF BROKE OR MALFUNCTIONAL) YOU WILL RESET CLOCK RADIO AND LIHT.
CLICK HERE
TO READ
KIA MOTORS COMPLAINT
