Need a wiring diagram to see if I placed the yellow and black wires in right location
SOURCE: Poter-Cable 135PSI Pancake Compressor
Check the pressure switch, they can become stuck in the open position. You can jump it to see if it is functioning or use a multimeter if you have one. Assuming that you've oiled and taken care of it it is unlikely that it simly quit, but that could happen... check across the poles of the motor for continuity which will tell you if the electric motor is blown. ALso make sure the compresor is not seized...
SOURCE: won't build pressure air compressor
most probably the one way valve in the heads unless the drain tap is opened
SOURCE: Porter cable pancake unit blows air after shut off.
tap on the check valve with a metal object. Its sticking open. The check valve is the brass fitting on top of the tank. When the valve sticks open it emits air from the area of the engine. If that doesn't work (which I would be surprised it doesn't), you'll need to purchase a new check valve. Good Luck!
SOURCE: no air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
