Just stop booting then keyboard is not functioning
the same problem here but when i try to press DELETE it is not woeking for me :( Any solution?Please hellp
Exact same problem. USB also does not work. Took it to Chicago Computers before the problem happened because the computer was slow, and when we got it back from them, the problem started.Exact same problem. USB also does not work. Took it to Chicago Computers before the problem happened because the computer was slow, and when we got it back from them, the problem started.
You can't post conmments that contain an email address.
Plug in a very cheap basic keyboard preferably not usb if u have the jacks. also you can disable usb keyboards in the bios so thats probably your problem. unless this is a laptop then i have no idia
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
you can fix that problem with your own. press f2 and then correct the time and date, then press f10. I f you got same problem again change the cmos battery then do it again.
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
may be
but you try this methods
remove the cpu cover and remove the cmos battery then ,remove the hdd cable and replug ,make sure all input devices like keyboard,cd rom drive conneced properly,then run the pc,F1 appears -click F1,after os load ,turn off the computer and insert the cmos battery ,again F1 is appears u press F10 and again press F10 or save buttens ,
it is a possible solution not sure,but try it
thanks
First Press all the keys on the keyboard (computer on or off)a sweeping motion accross all keys will do, A stuck key can prevent windows from booting (seen as a keyboard error).
it is also possible that your keyboard connector has come loose, check the keyboard connector (you will need to remove the facia above the keyboard and may have to undo a couple of screws to do this).
could try to plug in an external keyboard, see if this allows you to bypass issue
