Red light goes on but not the green light
SOURCE: HITACHI 42HDS69 connect to PC
I have the same question /problem. I recently ordered a cable that has the a computer monitor connection on one end and the "s-video"connection on the other end. This might work. I will post a new reply when I get the cable sometime between 8/4-8/7; if it works I will post a new message
Mightwork
SOURCE: 42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
SOURCE: Hitachi 42HDS69 42 in. Plasma with red lines
I think you have dry solder joints on the tv. Either on the chroma board, the vertical scan board, the line output board, or on the focus board. If you are going to do this yourself please take all necessary precautions against electric shock and discharge all capacitors that you can as a stray spark from one can cause damage to your tv and yourself. If you are not able to do this find a competant technician. Good luck.
SOURCE: 42HDS69 plasma Hitachi
My had the same problem, red light on bule led on but no sound or picture ...can any one help??? I appreciate
