Replacement of steam broiler
SOURCE: Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
SOURCE: gaggia baby espresso machine - water comes out of
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
SOURCE: Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Testimonial: "Thank you very much for your quick response. I've ordered the steam switch. "
SOURCE: How do I de-scale my Gaggia espresso machine?
Here a small manual on descaling, you might have to remove the steam wand or use a paperclip to clean out some of the crud in the wand.
SOURCE: Gaggia Titanium Espresso machine problem: steam
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
