Samsung TV Remote Control Logo
Russell Netto Posted on Jan 13, 2013
How to find source for model WS-28W63N without the remote control
We do not have the remote control for this TV so cannou use the source button to find the HDMI input for our new HD SkyBox
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Jan 14, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
2475
Points
20
Sometimes you can unplug the hdmi cable and power off the tv and unplug power to tv wait 10 sec plug tv back in and then insert hdmi cable. Some of the newer tvs will auto tune to the input if that dont work, try getting a universal remote program the remote to control tv if you can control tv volume, power , menu then you should be able to navigate to the input menu and select hdmi that way
3 Related Answers
Anonymous
  • 1922 Answers
  • Posted on Nov 01, 2009
SOURCE: Samsung TV model CT 5029V - Lost remote control - AIR/CATV
do you have a menu button on the t.v. itself? if so gain access there
Anonymous
  • 246 Answers
  • Posted on Mar 04, 2011
SOURCE: Hi, I just got a new samsung tv and my remote that
Refer to your dealer about this situation, hence there is no problem with your remote control. If some buttons are working others not, then the remote could be different. On the manual, there is a model number for the remote, if it does not match with the model number on remote, then change it.
Anonymous
  • Posted on Mar 30, 2009
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
How to configure our television
You're asking about the setup procedure to synchronize your TV with a remote control; I assume, and posts this solution. Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
tip
Reset Mitsubishi WS-73711 VChip Password
Bypass or Reset Mitsubishi WS-73711 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 73711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-73711 Manual Download
Bypass Mitsubishi WS-73711 Front Lock
on May 05, 2010 • Televison & Video
tip
Reset Mitsubishi WS-65712 VChip Password
Bypass or Reset Mitsubishi WS-65712 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65712 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Mitsubishi WS-65712 Manual Download
Bypass Mitsubishi WS-65712 Front Lock
tip
Reset Mitsubishi WS-65711 VChip Password
Bypass or Reset Mitsubishi WS-65711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Mitsubishi WS-65711 Manual Download
Bypass Mitsubishi WS-65711 Front Lock
on May 04, 2010 • Televison & Video
tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
tip
Reset Mitsubishi WS-65511 VChip Password
Bypass or Reset Mitsubishi WS-65511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 65511 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-65511 Front Lock
Mitsubishi WS-65511 Manual Download
on May 03, 2010 • Televison & Video
tip
Reset Mitsubishi WS-55711 VChip Password
Bypass or Reset Mitsubishi WS-55711 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi 55711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-55711 Front Lock
Mitsubishi WS-55711 Manual Download
tip
I hope that helps.
tip
Reset Mitsubishi WS-48511 VChip Password
Bypass or Reset Mitsubishi WS-48511 HDTV V-Chip Password Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
I hope that helps.
Bypass Mitsubishi WS-48511 Front Lock
Mitsubishi WS-48511 Manual Download
tip
Reset Mitsubishi WS-B55 VChip Password
Bypass or Reset Mitsubishi WS-B55 HDTV V-Chip Password Lock
I hope that helps.
Mitsubishi WS-B55 Manual Download
Bypass Mitsubishi WS-B55 Front Lock
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
