There is two times possible in this watch ADP6016. • Those times are named T1 and T2. • IMPORTANT: When your displayed time is T2, you CAN NOT set the time but just set the offset of T2 relative to T1. • You can see which time is displayed by looking for a very little T1 or T2 written just above the seconds • To swap the displayed time from T2 to T1 (or contrary), you have to long press the start/stop button (top right white button) • When your displayed time is T1, you CAN set the time with the solution given by soulgirljen just before this one
For Super Storm watch: Click Mode (upper left) button until either current time blinks (1st click) or current alarm time blinks (2nd click). Immediately (before the blinking stops, approx 3 seconds), click hours (lower left) and minutes (lower right) to set time. When you pause the clicking, time or alarm will be set.
The Toy Watch website has instructions on setting the time. Not sure about the date:
Setting Your TOYWATCH
1. Unscrew crown by turning it toward you.
2. Pull the crown out until you hear a click.
3. Turn the crown to set the time as desired.
4. Push in the crown and screw away from you until it is
tight.*
* If crown is loose warranty covering water damage may be
voided.
When you're in the regular time mode press "set". The secons should blink. Pressing "mode" brings you to the hour spot (hour should blink). Press "adj" to change the hour. To set the min., press "mode" again and the min. spot should blink press "adj" to change. Keep pressing "mode" then "adj" until all necessary time components are set correctly. Press "set" to get to regular time mode.
Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish
