SOURCE: my ti-83 plus has OS problem
the buttons are *hold clear and take the battery out then put it in dont release clear until you turn on the device* OR * the same with the DEL button
SOURCE: TI-83
try resetting the memory
that usually fixes problems related to a program running the the background or something like that
SOURCE: my ti 83 plus calculator wont go on
First of all, and I mean no offense here, check that
the batteries are inserted correctly, respecting the polarity +-+-. The
flat part (bottom) of the battery is the one that sits on the
protruding helix-like electrical terminal. Inside calculator, there is
polarity diagram.
When you change batteries, the display
contrast may become too dim (too light) for the user to see anything.
In that case, it can be adjusted.
Adjusting the screen contrast. Here is how to do it.
There is a key labeled 2nd. It is blue on the TI84Plus, and yellow/orange on the TI83Plus.
The
lack of screen contrast is the most frequent cause of 'malfunction'.
Try readjusting contrast, as described above. If that does not solve
the problem, post a comment to this thread detailing what you did and
the calculator response and we will troubleshoot further.
Good luck.
SOURCE: My TI 83 Plus won't work
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
