When i push the lock button on the remote the inside panel lights will come on and when i push it again they will go off..but door locks won't lock or unlock. it is a 2008 sx4 Suzuki.
Were the lock and unlock wires connected to the system?
Lock: Gray/White (-) @ 40 PIN CONN OF BCM PIN 27
Unlock: Gray/Red (-) @ 40 PIN CONN OF BCM PIN 26
Do you have a Smartpass key or a regular key? What bypass are you using for the remote start system?
just got a 791 bypass and we are going to install it today.
thanks for all help. didn't know i need a bypass if the car engine would start
i'll let you know what happens next.
SOURCE: Bulldog deluxe 500 doors will not operate with the remote
Bulldog has it BAD that Way I have seen this More than Once I nstalled one In A Chevy Blazer and 7-8 Months Later it Started "STARTING ON ITS OWN There HELP LINE NEVER HAD An Answer for Me So I Disconnected it Keep Tryin or Send it Back To them Sorry Not So Helpfull I Just Would Disconnect it
SOURCE: I have two remotes and only one will work
I don't know if you have the owners manual if not you can go to the website and find the programming instructions there.
Alan i thank you so much for the answer. i forwarded these to my mechanic. will let you know the outcome.
we tried solutions but still doesn't work.
