Dishwashers Logo
Paul Matus Posted on Jan 07, 2013
Diagnostic sequence for KUDS30IXSS1 dishwasher
How to reset kenmore elite dishwasher m#665.13973k015
How to Reset the Control Pannel for a Kenmore Dishwasher Quiet Guard 2
  1. Unlock the dishwasher control panel before resetting it. ...
  2. Press the following sequence of control panel buttons in quick succession: "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash."
  3. Allow the dishwasher to perform a brief diagnostic tes
Dishwasher won't start.
If it won't complete diagnostics, replace the main control Help Me Find My Model Number RepairClinic com
1helpful
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
How to reset a Kenmore 668.1687582 dishwasher
Yes, depending on the model, and the buttons that your dishwasher has, try the following key sequences:
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds.
Reset kenmore dishwasher
The most common "reset" key sequences are:
The "cancel" light blinks on and off rapidly. If we push start for the cycle the dishwasher clicks off and on intermitently.
To solve this you will have to reset the console. Do this by closing the door and press these buttons in sequence
-high temp wash -heated dry -high temp wash -heated dry
After doing this sequence all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).You should now be able to run the dishwasher as normal.
Thank you!
13helpful
How do i reset my dishwasher when the light is flashing AND NOT WORKING
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
2helpful
Kenmore elete dishwasher flashing light clean
-high temp wash
-heated dry
-high temp wash
-heated dry
10helpful
Whirlpool gu2400 dishwasher
-high temp wash
-heated dry
-high temp wash
-heated dry
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
