My heater unit doesn't blow any air when it's turned on , I can hear the vents coming on , but no air is coming out of the vents . I have checked the fuses and they are fine .Maybe the cold weather is the problem because car doesn't have garage , maybe I just need to reset the system , because heater was fine day before and one day it has just stopped working .I don't know ? please can anyone have solution or had similar problem ?
SOURCE: My car air conditioner works fine when car is
hi,
seems like your air con relay has gone bad. that what happened to my ford xr6. you need to take to car to air con technicians, since it is not user serviceable.
kind regards
RAhUL_hunk
SOURCE: 02 Jaguar S Type - Heater blowing cold air
Has the vehicle overheated recently, if not there is a failure of the Coolant from engine valve controller, that measures flow through the Heater Matrix. Come back with more, as necessary.
Regards,DT
SOURCE: heater not working it is blowing cold air at all times is there a
Heater blowing cold air until I get on the interstate, then it works; however, when I stop at lights it starts blowing cold air again. The temperature gauge will be in the middle but the car will still be cold until the car starts moving.
SOURCE: my heater is blowing cold air... when i turn it on
Please see my tip at http://www.fixya.com/cars/r6235876-no_heat_fan_blowing_cold_air . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
