Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Honestly it's unlikely that you can. When I worked at dealerships and sent out cd changers to be fixed under warranty, the manufacturers would usually return the disks either broken or scratched up.
I don't think the cd changer mechanism is ok if it reads err continuously or with more than a few cd's.The lens may be dirty, but in many cases it may need a new cd-changer mechanism or another cd-changer altogether.
The in-trunk units have a tendancy to go bad. you can take the cover plastic interior cover off to access the CD changer, un bolt the changer, and visualy inspect the two rollers for debris, or missing /broken gears that move the rollers to take the CD from the CD cartrage to the player. if that looks fine, chances are that the laser went bad (common in rear mount units) and you can order a new one from Jeep, or you can remove it and update the in-dash head to an aftermarket of your choice (& yes you steering wheel controls will still work). you could also fit a more modern MP3 unit where the Changer was.
Have a 2005 Freelander and the battery died. When I re-charged the battery, the CD changer had a CD ERR 1 message. Could not eject or load a CD and the radio worked. I turned off the radio and pulled off the cover on top of the CD changer. I removed the two screws that hold the frame around the CD changer. I turned the CD back on and the CD went through a test on each CD. I know this solution might not work for everyone, but it worked for me
