Compaq Presario M2000 Notebook Logo
Patti Springer Posted on Dec 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer is slow loading - Compaq Presario M2000 Notebook
Anonymous
Level 2:
Novelist:
  • Expert 250 Answers
  • Posted on Dec 20, 2012
Anonymous
Expert
Level 2:
Novelist:
Answers
250
Questions
0
Helped
60460
Points
320
Perform the following tasks:
  • Scan with Anti-virus
  • Scan with Anti Spyware
  • Fix Registry errors
  • Disable unwanted services
  • Remove unwanted programs
For an instant fix use a PC Optimizer like Reginout for complete PC optimization.
max carson
Level 3:
  • Compaq Master 7,627 Answers
  • Posted on Dec 19, 2012
max carson
Compaq Master
Level 3:
Answers
7627
Questions
Helped
1015304
Points
21773
Take a look at this: http://www.wikihow.com/Speed-up-a-Windows-XP-Computer
Many FREEWARE programs can be found here: http://www.filehippo.com/ CCLEANER, MALWAREBYTES, etc.
1helpful
2answers
Why do my computer loading slow and shut down real slow?
May have malware...try a good antivirus to scan system...and clear temp files.
Cant load warcommander on my computer that has windows xp on it
Make sure that your system meets minimum requirement for playing warcommander. If Yes, then download it. If your loading is slow then it means your internet connection has slow speed. I would suggest to download and install Reginout and use its Internet Optimizer feature.
Thanks
2answers
Firefox slow loading
down load the latest version or update your version
slow loading can be from your modem speed , excessive memory usage or failing hard drive
Dell computer slow loading
Every file you download or program you install is going to slow down your Dell computer. It has been often observed that as a computer becomes old or is used repeatedly, it tends to perform sluggish while downloading or accessing files\programs etc. or throw errors randomly.....
Here steps to make dell computer run faster
My computer is too slow - how do I make it faster?
Slow Start Up
There can be a variety of reasons to Windows loading slow during start up. Go to Run, type msconfig and hit enter. Under the 'Start Up' tab, uncheck the unwanted programs and press OK. Things should be a bit fine the next time Windows boots.
Another program worth mentioning here is StartUp Delayer which will help in setting after how much time programs should be loaded after Windows boots. For instance, you could set your instant messenger program to load 50 seconds after Windows starts up.
Slow Loading Start Menu
If the Start Menu items are loading slowly, you can open the Registry Editor by typing in the Run menu 'regedit.exe' and pressing Enter. Go to HKEY_CURRENT_USERControl PanelDesktop. Look for MenuShowDelay, and double click to edit the value. The lower the number specified, the faster the Start Menu will load.
Slow Right Click Context Menu
Probably the Windows Right Click menu on your computer is loading slow because too many programs added unwanted entries there. Just download this program called Mmm, install it and then modify your context menu to remove unwanted items to speed it up.
win-fixes-send-to.jpg Slow Send To Menu
If the Send To menu loads slowly, you can type 'sendto' in the Run Dialog, and remove unwanted items in the Explorer Window that appears. This should add some speed to it.
Slow Defragmentation
The Windows Defragmenter can't get any slower. You need to have an alternative to the Windows Defragmenter, and Defraggler is just one of the best ones available in the market. It's free, and works like a charm and can speed up defragmentation manifold. For some alternatives, see Five Free Programs to Defragment your PC.
2answers
My computer starts at the blue start up screen and it takes it about 10 minutes to load the log in screen. It wasn't doing this at first. I have done multiple system restores, but it hasn't helped....
hi Jamiekom.
Slow Running Computer Fix. Use MSCONFIG to improve computer's speed at startup. You can disable certain programs that auto-start at startup and spend less time waiting for your computer to fully boot. Simple tip to improve your computer's performance.
Why is computer so slow to startup? My Windows computer boots up slow. A slow Microsoft Windows boot up can be caused by a number of different issues. The following document contains various suggestions and tips that can help improve the overall speed of your computer's startup.
Why does it take so long to boot up my computer?3. Upgrade your hardware. A new computer is naturally going to start up faster because it has faster hardware, and a clean operating system. ... As we said above, computer startup is slow because you're moving information from a slow hard drive to faster RAM
Computer running slow at startup Check out this Quick Tip
computer slow on start up Google Search
Why is there slow printing when I type from key pad to the computer screen
this will happen when your computer is over loaded , that is the memory is over loaded, when it is over loaded , the system hangs and makes every thing work slow. This is the right time for a virus to gain entry because the system will work slow that by the time the virus gains access , the system takes time to activate the antivirus or the firewall.
So i recommend you to clean up your PC and increase your system memory.
Thanks for rating Good luck
2answers
My videos not to fast on YouTube
its not problem with youtube. you should change some settings for youtube, your settings might have been changed, Youtube load videos according to your connection speed. your should change your setting and modify the settings to load low quality video if your internet connection is slow and load high quality for faster internet connection.
click on the link below and login with your youtube account.
http://www.youtube.com/account?feature=mhsn#playback/quality
My windows xp home is slow on loading websites as compared to other machines on the same wireless. What could be the reason for this
There could be many possible reasons for your machine being slow loading websites:
- Do you have a lot of programs running in the background?
- Are you using the same browser as the other machines on your network?
- Does your computer have as much RAM as the other computers?
- Is your wireless adapter as fast as the adapters on the other computers?
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
