Televison & Video Logo
A
Anonymous Posted on Dec 10, 2012
Extender code 8 digit number my vizio tv
I need my extender code for window media center it keep say look on my tv for the code 8 digit number i don't see it no where on my vizio tv
2 Related Answers
walesarumi
Wale Sarumi KomputerSolution
  • 6993 Answers
  • Posted on Aug 10, 2011
SOURCE: I have two Vizio 26"
the remote sensor/infrared on both TV's are very sharp and effective, that is why the remote keeps controlling both TVs at the same time.
There is no way to make the 2 TVs independent expect you separate them very far from each other. Both TVs are not far enough, that's why the remote control keeps controlling both.
One other thing you can do is to use a paper tape to block the remote sensor/infrared on one of the TV. By so doing, the remote won't control one of the TV. Though this would be very stressful because you will have to block and unblock the sensor all the time. But there is no other trick to this.
Let me know if you have any objections.
Regards.
gopakumarg43
  • 76851 Answers
  • Posted on Jun 06, 2012
SOURCE: is my tv compatible with windows media center?
Download the user manual and refer it.
How to setup xbox 360 windows media centre
Instructions for Windows 7
1. Connecting the console to the network
Press the Guide button on the Xbox controller.
Go to the Settings page and select System Preferences.
Select Network Settings.
Select your wireless network or select Wired network if you are using a wired connection.
Select Test Connection to Xbox Live.
If the network connection status is Connected, go to step 2. Otherwise, select More information on the console and follow the instructions.
2. Delete previous connections (if necessary)
Launch Windows Media Center.
In the bottom section of the menu, click the down arrow and select Settings in the Tasks section.
Select the Media Extender section.
Select Xbox 360 Media Center Extender.
Select Delete.
Press 'Next.
Actions on the console. Delete previous connections
Go to the My Settings page and select System.
Select Computers.
Select Windows Media Center.
Select Disconnect.
Press the B button on the controller to return to the Xbox control panel.
3. Getting the installation key on the console
On the console, go to the Applications page, select My Applications, and then Windows Media Center. Tip. Don\u0027t see the Application item? You might need to update your Xbox 360 console software.
Choose Continue.
Record the 8-digit installation key.
4. Adding a console to Windows Media Center
Launch Windows Media Center on your computer.
Go to the Tasks section and select Add media box.
On the setup screen for the media extension, click Next.
When prompted, enter the 8-digit installation code obtained in step 3.
Click Next to complete the installation.
5. Launch Windows Media Center on the console
Go to the Applications page, select My Applications, and then Windows Media Center. When you first open Windows Media Center on the console, it will take some time to build the media libraries.
Done!
Code for connect windows media center to tv
Instead of trying to connect this to your TV via 8-digit code, you should try running an HDMI cord from your computer to the back of your TV. Quality of picture is better, and it streams flawlessly.
How do i connect my 360 to the computer
I had this same problem and found this great video on youtube.
go here:
http://www.youtube.com/watch?v=BaKgCYkSCjc
over 175,000 views
if you click the drop down on the info you'll see the step by step instructions.
STEP 1
If you were previously using your Xbox 360 with a Windows XP Media Center Based PC, you will need to remove existing connection. Otherwise skip to step 2.
At the Windows XP Media Center PC
Click Start, point to All Programs, point to Accessories, point to Media Center, and then click Media Center Extender Manager.
Select your Xbox 360 and click Properties.
Click Remove.
Click Yes to confirm removal.
At the Xbox 360
On the Xbox 360, go to My Xbox and then System Settings, then select Computers.
Select Windows Media Center, and then press the A button.
Select Disconnect.
Press the B button until you return back to the System Settings.
STEP 2 Gather Setup Key from Xbox 360
Press the Media Center Start button on the remote or go to My Xbox, then select Windows Media Center.
Advance through the on-screen instructions to obtain the 8 digit Media Center Setup Key. Write this key down.
STEP 3 Add Extender
At the Windows Vista-based Media Center PC, launch Windows Media Center. Select Start, Windows Media Center.
Select Tasks, Add Extender.
When prompted, provide the 8 digit setup key you received at the Xbox 360.
Complete the Extender setup.
STEP 4 Print the Media Center Quick Reference Guide
Please can you tell me how to wifi link media center between my xbox360 and my laptop running windows7? Every website has different advice! PLEASE help. Sincerely; Dr Gary Drake.
Step 1: Get Setup Key from Xbox 360
  1. On your console, go to My Xbox and select Windows Media Center.
  2. Follow the on-screen instructions.
  3. Write down the 8-digit Media Center Setup Key.
Step 2: Add an Extender on your computer
  1. Start Windows Media Center.
  2. Click Tasks, and then click Add Extender.
  3. When prompted, enter the 8-digit Setup Key from Xbox 360.
  4. Complete the Extender setup.
How do i share media with my xbox ?
Basically, what you need is a Windows - based computer. Follow these steps on the setup:
ON YOUR XBOX 360:
• go to media center on the dashboard
• and follow the on screen prompt
• it will generate an 8 digit code (better to note it down)
• go to your Windows PC
ON YOUR WINDOWS PC
• go to Media Center
• go to "tasks"
• select settings and configure media center extender
• select your Xox 360 and once asked for the 8 digit code, enter the code you noted
• confirm the changes
Finalize the set up on you computer and Xbox 360 and you are ready to go. If you will encounter any problems please let me know.. Cheers!
My screen shuts down when i go to media center? i cant figure out what my 8 digit set up key extender # is to get the tv to work
do you have the pc connected to a tv and a monitor it may be defaulting to the other and the extender key is usually for an xbox or something else that has media network properties hope this helps you bud
I have a belkin g router i connect my xbox 360 to it but when i try to get online with xbox it says computer not found
What you are going to have to do is configure your computer, (which should have Windows Media Center) to see your xbox. You do this through the media center. Open up the media center on your computer which is connected to the same network as your xbox. Go under setting and add extender. go to media center on your xbox get the 8 digit number enter it on your computer and let it configure
Xbox set up
If you have an Xbox 360 connected to a home network that also has a Windows Media Center, you can add your Xbox 360 as a Media Center Extender device so that you can enjoy the digital media on your Windows Media Center computer by using Xbox 360. For more information, see Xbox 360 online.
1. Turn on your Windows Media Center computer and log on to Windows. Verify that your computer is connected to your home network.
2. Turn on your Xbox 360 and verify that it is connected to your home network.
3. In Windows Media Center, on the start screen, scroll to Tasks, and then click add extender.
4. On the Welcome to Windows Media Center Extender Setup screen in Windows Media Center, click Next.
5. Press the Green Start button blank.gif on your Xbox 360 remote control or use your Xbox 360 controller to select the media blade.
6. On your Xbox 360, select Media Center.
7. On your Xbox 360, follow the instructions on the screen to obtain an 8-digit Windows Media Center Setup Key. Write down this 8-digit setup key. This is the key that you will use to affiliate your Xbox 360 with your computer that has Windows Media Center.
You do not need to download any additional software because the Extender functionality is built into Windows Media Center.
8. On the Enter the Setup Key screen in Windows Media Center, use the Windows Media Center remote control or keyboard to enter the 8-digit setup key that displays on Xbox 360, and then click Next.
9. Follow the steps in Extender Setup.
Several changes are automatically made to your Windows Media Center computer during the Extender Setup, including changes to the Windows Firewall settings. For more information about Windows Firewall, see Windows Firewall: recommended links. During this time, the Windows Media Center Extender service (which is named mcx2svc) starts on your computer, along with other dependent services.
If you have a firewall running on your computer that is not the Windows Firewall, make sure that the firewall software is set up to allow Xbox 360 to connect to your Windows Media Center computer as a Windows Media Center Extender. Some firewalls are already set up to allow Xbox 360 to connect to a Windows Media Center computer as a Media Center Extender. However, other firewalls will require you to make changes to how the firewall software is set up. For more information about which firewalls are already set up to allow a Media Center Extender connection, as well as information about how to set up other firewalls to work with a Windows Media Center Extender such as Xbox 360, go to the Firewalls and Media Center Extender article on the Microsoft website.
10. After Extender Setup has finished, in Windows Media Center, click Finish.
On the TV that is connected to Xbox 360, the Windows Media Center user interface appears. You can then enjoy live TV, recorded TV, pictures, music, videos, and other digital media on your Xbox 360 as you would in Windows Media Center. A new user account named mcx1 (by default) is automatically created to use the Extender.
Please see http://windowshelp.microsoft.com/Windows/en-US/Help/8076aff3-16ec-4751-9f57-d36e0ff407201033.mspx#EPD for more info.
Thanks and hope that helps!
Les
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
