A fuse popped while the TV was on and after we switched the fuse back on there is no sound on the TV. Have tried the other inputs and same problem.
Could be a audio output circuit problem but if just using the speakers built into the set check in the set menu to make sure for whatever reason the speakers are now not switched to off.
With the correct cable or sat box and a surround sound system you might be able to get around this---just a thought.
SOURCE: Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted
due to a power failure or fluctuation. Here's how to determine which is which:
The picture and everything else work fine just no sound at all. Slient. No hissing, popping or fuzziness. I'm praying the speakers aren't blown
