If your BlackBerry Bold 9000 series device is frozen or not responding, you will probably want to reset the unit. Here are the different types of resets that can be perfomed in the order they should be tried. Soft Reset PressALT + RIGHT SHIFT(CAP) + DELETE. Double-Soft Reset PressALT + RIGHT SHIFT(CAP) + DELETE. The screen will go blank for a few seconds. When the screen comes back on, immediately pressALT + RIGHT SHIFT(CAP) + DELETEagain. Hard Reset If none of the above works, pull the battery out of the unit for a few seconds, then reinsert it.
Here is where you buy a users guide. Ribbon printers are switched to bold by sending an 'ESCAPE SEQUENCE' to the printer just before you send the print out for that line of text. The escape sequence should be in the owner's manual. Word for Windows will Automatically print correctly in bold if the text is bold, if the right driver is loaded. I cannot find a driver. The driver should be IN Windows.
In you're Blackberry bold 1) Go to Media 2) select vide's 3) Highlight the video's files which you like to delete 4)press menu key and select delete you will be able to do that.
I have a Bold personally and try a soft reset. You won't lose any data but press the alt key on the left, the shift key on the right, and the delete key on the right simultaneously. This is like control-alt-delete on your computer.
you have not specified which Blackberry you (from your provider or an unlocked one) but to put back Messenger back inside you need to download the latest Blackberry software from THE CARRIER THAT IS ON YOUR BLACKBERRY (whichever logo is printed on your blackberry) and install it on your computer. Then using the Blackberry Desktop click app loader and select Messenger to load to your blackberry
Yes sir! A "Hard Reset" will COMPLETELY reset the all interface back to factory default.
If you use the Blackberry Desktop Software you can easily, back all your data first, then initially "hard reset" the device. After you have performed the necessary steps you can restore all your data.
there is a key that has BOLD printed under the letter on the key, or it may be printed above the top keys on the keyboard, hold down the code key and hit the key under where it says BOLD, or the key that has it on it. to take it off, do the same thing
