WEBcam image problem Most WEBcams have a setting to mirror or turn the image upside down etc. Go to your WEBcam setting to set your image back to normal.
In MSN, go to Tools-Web cam settings, there's an option to invert the view, check it and you'll see in the preview that your perspective is inverted now :-) Accept and it's done :-)
Resolution
The image in your Webcam Uploader window might be inverted because of your camera settings.
To change the settings:
Click Messenger and select My Webcam.
In the window that opens, click the File menu ' select Preferences ' choose Webcam.
Click the Camera Settings button.
There is usually a checkbox for "Invert Image" or "Mirror Vertical." Un-check this box if one exists.
If you mean changing the image produced by your web cam to a mirror image, then this is what you should do.
Though, the process may vary as a result of what camera software you have installed. Start your web cam. Go to the settings. Select camera settings. You would see the options to flip the image horizontally. Do that to set the mirror image. Some software might not indicate the flip option, rather, it would ask to select 'mirror image'. Select whichever is appropriate.
Ok im not sure what cam you have or comp that your using, but cahances are you need to go to your web cam settings:START/ALL PROGRAMS/ "your cam"/ CAM SETTING. there you should see inverted or mirror settings, it might even be in ADVANCED SETTINGS try and look for it, Good luck JLS
P.S. you could always turn your cam upside down! LOL Just kidding!
