Main oven not heating up
SOURCE: tecnik tkc 8522-8525
You need something thin and strong to slide underneath the screw head. Then turn slowly while lifting the screw head. The thread should catch and the screw should back out.
SOURCE: i have a tecnik tkc 1255/ss range oven serial
You dont happen to have the LPG jets that were supplied with the cooker do you? I'm having trouble getting hold of any?
Thanks,
SOURCE: tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
SOURCE: I have a Tecnik TKC
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
SOURCE: I have just moved into a new house which has a
I have asimilar problem. HAve you solved it yet ?
