When you turn on the car sometimes you have to turn it on 2 times to get it to start
CAR NO START PROBLEMS:----- It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue. From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:----- What to Do When Car Turns Over But
Won't Start? http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html ----------- http://technoanswers.blogspot.in/2012/02/car-starting-issues.html ------------ http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html -------- http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html ---------- http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html --------- http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html ----------- http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html ---------- -------------- -------- http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html ---------- --------- http://www.howtorepairguide.com --------- These will help. Thanks.
Car starting issues?
Car Starting Problems
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
1994 Toyota Pickup: Starts fine but dies in
few seconds?
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
2001 Toyota Camry: No start After replacing Battery?
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
SOURCE: volkswagen transporter 2 5 tdi white smoke
Hi, Luke
White smoke from the exhaust is typically oil burning, caused by, worn valve seal(s) - worn or broken piston ring(s) or a broken head gasket, thus allowing excessive oil in to the combustion chamber, but then most auto shops already know this and would require major engine dis-assembly to truly diagnose this issue.
Hard starting could be oil fouled spark plugs, a result of the same issue.
As a side note: I would take a friend who is somewhat mechanically inclined with you to "your workshop" to engage the person(s) to get an in-depth explanation as to how they checked your piston.
Do not purchase a fuel pump or that repair on an assumption, be sure
One of the tell tale signs of a fuel related issue is black smoke...
Could be a bundle of reasons, you might wanna check out the guide from Dig My Ride for an informative article that covers the common culprits for this problem. You should check your battery and alternator. A broken alternator will cause your battery to die. A weak or dead battery will cause problems when starting your car.
