2005 ford f-250 6.0 how compressor remplace
My assumption is this is the A/C compressor, First remove the freon for the system, you will need a special tool to disconnect the A/C lines, The parts you will need are new Compressor/w clutch and dryer, freon and refrg oil o-rings for a/c lines new restrictor for high pressure line. remove comp and dryer replace with new and proper amount of oil in compressor, replace high pressure restrictor and o-rings on lines once the system is completely together you will need a A/C vac pump to create a vacuum in the system be for the refrig is added to proper pressure for vehicle Compressor
