Question about Home
I have bought several shower heads as the spray pressure is low but none have helped. The pressure is ok on low setting on half heat but too cold. On full heat its too hot on min setting. Help plz ?
Posted by sam mccurley on
Adam Howard
    Habit-Forming:
  • 60 Answers
Replacing the existing shower head is not the way to fix the problem. But removing the flow restrictor from your shower head can be a better way to increase water pressure. Not all showerheads come with flow restrictors accept the new models.
This is an easy DIY task that you can do by following a series of steps. Gather a pipe wrench, needle nose pliers, dry cloth, and a dry cloth to make the task done.
For fixed showerheads, use a dry cloth to wrap the shower arm and connecting nuts to prevent scratches. After removing the head, locate the restrictor.
Remove the rubber washer with the needle-nose pliers and remove the flow restrictor using a flat screwdriver. Avoid peel off by wrapping the shower arm thread with Teflon tape. Then reinstall the head and check if it's fixed.
If you want to remove the flow restrictor from your handheld or Moen shower head, read the step by step guide.
I've found on the internet. Hope this guide will help you to the task easily.
Posted on Jul 20, 2020
  • 18,438 Answers
The problem is that all shower heads sold now have to be low water volume. You can take the restrictor out and see if that helps. Look for a blue or white plug type insert in the fixture that has a slot on it. Pull it out and you should be good.
http://homeguides.sfgate.com/remove-water-restrictors-showerheads-27817.html
and http://www.ehow.com/how_5189790_remove-flow-restrictor-shower-head.html
Posted on Jun 22, 2015
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
What's wrong with a leaking shower head following new boiler and how do I fix it?
The valves are leaking. It's not the shower head itself. Sometimes shower faucets require special tools to service the valves. If you have thought about new shower valves, now would be a good time to replace. Repair may be half the cost of installation of new. In other words, plumber's time to repair or replace is about the same. Get several quotes. TV show This Old House had one on a replacement. It may be available online. Home Depot or Lowes or Ace Hardware may be able to help, Or similar Hardware outlet in your area.
Feb 13, 2015 | Water Heaters
One of my HG shower systems has increasingly lower volume. The shower head and supply hose are fine. what should I check next?
If you are using water in another part of the house most times the pressure at the bathroom shower will go low. For instance if some one in the kitchen draws water in the kitchen sink this will make the shower water even turn cooler because of low pressure. Flushing the toilet will also do the same.
Most houses are plumbed with half inch water pipe and would work a lot better if it was three quarter inch to give more water pressure.
Jan 12, 2015 | Hansgrohe Home
Triton t80si shower is very hot even on a low setting then fluctuates between hot & cold, pressure switch is not activating but pressure seems low any advise will be gratefully received.
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Jul 09, 2010 | Home
Delta Victorian 5-Spray Hand Shower has no
hello
of corse ... sir want to get thread tape befor trying to fix the head .
unscrew the head of the shower not the arm.
after unscrewing the head ,look at the back were the thred is, there will be a siff. thust clean out the sif, put thread tape on the head again and bobs your uncel hehe. if that dosent fix it let me know .
Jul 08, 2010 | Delta & Victorian 5 Spray Showerhead
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
A plumber has just installed a shower which has uneven water supply pressure. The low pressure hot water from a head tank had a 3/4" pipe supply whichin spite of being questioned the plumber has reduced...
You aren't the first to run into this dilemna.
The size of thhe pipe will affect your system in this way.
If you start 85lbs of pressure in the water main, The meterhas a 1" pipe inlet and a 3/4" outlet. The meter reduced thhe pressure to60 psi and then it is reduced again at the point of entering the structure dropping to 1/2" pipe. By resucing the pressure is upped approx 5-7 lbs. The point of regulator and pipe size is the only time the pressure changes. The lowest pressure will drive a rainbird spribkler,actually several. But too many rainbirds won't affect by pressure as much as volume. The pressure will push whatever is available.By reducing the 3/4 to 1/2" didn't affect your pressure as much as it did your volume.. The reason your hot water starts to run cold sooner is that now you do not have the volume ratio between the cold and hot.It 's 1:1 now instead of 1.25:1. Hot more than cold. It takes more hot water to heat cold water than ittakescold to cool hot. Plus, the hot water you use is being replaced by cold water and that water is cooling what hot water is in the tank as the heat moves to the cold. The heater cannot heat al that water fast enough, but the cold water line is happy as can be.No pressure changes and no temperature changes. Before, you had to turn up the cold to bring the temp down to comfortable or safe. I just had my shower redone and everything is the sme size. Here is something to think about. Ck the shower head. They clog up and cause poor mixing over time. Yoou should be ok. How old is the water heater? Over time they get a build up of calcium and lime which is very detrimental to the heaters efficiency and recovery time. I hope this all made sense to you. At times when we have things done right it seems to be wrong because we are accustomed to the way it was. You will get accustomed to it and find your water heater gobbling less energy. Good luck and I hope it all works out, There is no need to fret. Sincerely -Ned-
May 21, 2010 | Home
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
Home Logo
265 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
