Can i connect two different nvidia graphics with SLI cable , and can those work together I have Nvidia Quadro FX 3700 and Nvidia Geforce GTX 7900 !! Thank you !
No
They use two different GPU's.
The Nvidia Quadro FX 3700 uses the Nvidia G92 Graphics Processing Unit, (graphics chipset),
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#Quadro
(Scroll down)
,and the Nvidia GeForce GTX7900 uses the Nvidia G71 G.P.U.
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_7_.287xxx.29_series
(Scroll down)
You need two LIKE graphics cards to use Scalable Link Interface,
http://en.wikipedia.org/wiki/Scalable_Link_Interface
Scroll down, read under the bold black subheading - Caveats
SOURCE: Setting up dual monitors with NVIDIA 7300 GS Graphics Adapter
so...
your computer don't recognize your nvidia graphic card in PCI Express slot.
you are runing now with computer's integrated graphic card?
if so then you won't have dualview option. in this case it looks for me like you've installed in the wrong way your graphic card.
your NV GeForce 7300 GS has 2 video output?
if yes then you should have the option for 2 monitors on nVIDIA control panel (i have check my nVIDIA GeForce 7600gt and in my case this option is present but is enabled only if i connect the second monitor, so try do so)
you have installed the latest nVIDIA drivers from the official website? http://www.nvidia.com/Download/index.aspx?lang=en-us
check if your video card is corect installed start/run type in " devmgmt.msc ". it will open device manager and under the display adapter tab you should see what video card you use now.
SOURCE: Want to upgrade my video card
Yes, your FX1100 will work, according to HP. Please refer to this link http://h18000.www1.hp.com/products/quickspecs/11604_na/11604_na.HTML
for additional cards that are supported by your system.
SOURCE: i have a hp iq780 touchsmart pc.recently nvidia
if the hw is working fine then you can go to the device manager and uninstall the driver ... and then go to the nvidia website and install the driver sw for it
SOURCE: i am having trouble installing
Do you see something like advanced BIOS options? If not then Note down the list of all BIOS menus and options under them , and post them here. Do this and I guarantee that I can resolve your problem.
SOURCE: Installed GEForce NVidia 8400GS graphic card but
Assuming that you have installed the drivers for your new board, go into Control Panel, select Device manager and Display Adapters.
Dissable the onboard adapter and enable the NVidia card.
