When we are on a road trip the gas will quit working We cannot get it to work, so we take to the shop. They say it is fix before we get it home it will quit. four times already. elect works fine
SOURCE: Throwing breaker when plugged up to AC
The heating element most likely has a short in it. Pull the to leads leading to it test the ohms to see if you have a short
SOURCE: rm 2611 will not run on gas when going down the road
Your voltage supply is being interrupted. The DC voltage needs to be at least 10.5 to work properly. If you are switching from shore to gen this can cause the interuption also. I presume the gas supply is staying on when you are traveling.
SOURCE: Works good on electric. The freezer freezes on
make sure your gas level is right. low gas levels can cause your problem
SOURCE: freezer side works fine ref side works for three
CHECK BAFFLE FROM FREEZER TO REFIGERATOE SIDE
