Canon PowerShot A550 Digital Camera Logo
Posted on Jan 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am having to manualy open my shutter to take a picture. Any suggestions on a quick fix?
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on Jan 07, 2009
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1196038
Points
12483
Think you're probably referring to your automatic lens cover. If so, this blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be somewhat similar for an A550. The exception being that the A550 has four shutter leaves instead of simply two as the A400 has. Highly recommend trying the non-obtruisive fixes first, and giving them a second try before going in there:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
My sons kodak easyshare cx6230 only takes black/blank images. Screen works, but all photos taken are black. Suggestions please?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
2helpful
2answers
Hi, I too as a Guru have offered many solutions and help to the FixYa community and I now require the help of another member if possible. I am looking for a service manual for a Fujifilm Finepix S1500...
Hi, ok dear for repair manual visit uscamera.com also parts; your camera have probably lens shutter fpc broken and shutter does not open.
Replace of lsfpc dont need adjustment , but lens unit replacemet yes ned af adj..
Greethings
Feb 17, 2011 • Cameras
I have a Canon PowerShot S2 IS and all of a sudden I cannot get an impage in view finder nor the flip lens. Any suggestions?
A stuck shutter is another common failure mode for digital cameras, but especially for the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
The problem I am having with my Canon PowerShot S2 IS is the iris is staying closed. No matter what I do it just stays closed. What could have caused this? How would I fix this problem?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
As you own an S2, if you live in the US, recommend contacting Canon first as mentioned in the link. Although it's highly likely that you can quickly fix your camera with the techniques shown in the article, why not get professional free repair from Canon if it's offered? The Canon repair may help prevent this from happening again.
I first experienced a problem with my Canon S2Is camera when it was only taking pictures of blank images. I found a "fix" recommendation which seems to have gotten rid of the black image problem. However,...
Think you need to do the fix more. Believe your shutter was previously stuck in the closed position. Now it sounds like it is stuck in the open position. Again keep trying the fix to loosen it up. Just to confirm, the "fix" you're talking about is taking repeated photos in shutter priority mode with 15 second exposures, and opening and closing the battery door while the shutter is opening, right? You may want to add some tapping of the camera against its padded usb cover in an attempt to get the shutter to jar closed.
Canon Powershot S2IS black screen can't take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). Not sure what causes this issue, but some say it's heat, others say it's dust.
But anyways, to confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
4helpful
2answers
My camera displays a "white screen" when i take photos "outdoors" or during daytime outside
Are you sure that you are in full "auto" mode when you are taking your pictures? Make sure that the mode selector is set to the first red camera (without the M) right next to the little blue arrow.
If you already are in full auto, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Your camera is not capable of taking 15 second exposures. Instead try putting it in manual mode, turn off the flash, take it in a darkened room, take the picture, and open the battery door while the red and yellow lights are blinking. Give it several tries, but note that the chances may be very slim for success as the shutter symptoms suggest that it is stuck open.
1helpful
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Display problem
Sounds like your shutter may be stuck. Turn off the flash (so that you don't blind yourself), then look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter/iris quickly opens and close. If no movement is seen then the shutter is stuck. Unfortunately, professional repair will cost many times the current value of the camera. But you can try the following fix to try to unstick it:
http://www.fixya.com/support/t295396-canon_s2_black_screen
Shutter opened but won't close
Switching off the camera from the main ON/OFF swit5ch should close the shutter. If it doesn;t, try removing the battery or the CF card. It is possible to manually increase the shutter speed even in bright sunny conditions.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
