SOURCE: 2001 kia sportage blower motor resister
Rule of thumb...unless you get a better answer: look for a couple of wires on a small plate that is in the airflow of the fan on the heater/ac unit. The resistor pack is always air cooled by the fan.
SOURCE: 1999 KIA Sportage, 2WD. No heat, fan, A/C
did you check the switch to the control cluster ? incase you dont know what im talkin about the switch that turns it on and off and adjusts speed? if its not that then do you have a blown fuse becouse the blower moter has an independant fuse some times in the fuse box there may be 2 1 in the car and the other under the hood try that let me know if its fixed
SOURCE: 2001 Kia Sportage fuse 4 radiator fan?
Radiator fan fuse is fuse # 5 (40 amp/Green) located behind the interior fuse access panel on the left side of the instrument panel next to the steering column. Also, in the underhood Power distribution center, next to the air cleaner filter are two black fan relays: high speed (F) at the far left, second row down and a low speed, 1st one to the right on the bottom row.
SOURCE: Replaced blower motor in my 2001 kia sportage ex,
It could be the blower motor resistor, the high position feeds full 12 volt power directly to the blower motor. All lower settings route through the blower motor resistor. It is usually located under the passenger side dash, not far from the blower motor. Two screws secure it to the heater box.
FAN NOT WORKING
It
can be issue with faulty motor or its faulty fan control relay.
Both
are to be inspected.
Test
volt at fan relay and fan motor.
For
more help, I suggest you to go through the troubleshooting link mentioned below:-----
Click
the link below: ------
Engine Cooling Fan not Working
http://technoanswers.blogspot.com/2012/11/overheating-radiator-fan-not-working.html
These will help.
Thanks.
Actually I have replaced the relay too
