I'm going to take a guess???? Do you have a Canon copier??? If so, the error code E0005 means that the fixing cleaning web has run out. I may just be that the counter needs to be reset. Odds are you will need to replace one or both of the cleaning webs, you did not give a make or model of the copier you have. To change the web is hard to say, there are way to many different ways to replace the web and ways to remove the fixing unit.... Good Luck
SOURCE: error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
SOURCE: i am getting error code e005 0100 how do i reset
E005 Error code details
Main Cause The fixing web has been taken up. The fixing web length sensor (PS45) is faulty. The DC controller PCB is faulty.
Mode of Detection
0000 The length of fixing web that has been taken up is in excess of the specified length.
Caution After replacing the fixing web, be sure to reset the two web counters in service mode: COPIER>COUNTER>MISC>FIX-WEB and COPIER>COUNTER>DRBL-1>FX-WEB.
