Contributor
- Posted on Jan 05, 2009
Re: I need help please! I need to re-program my RCA...
You may need more information about your tv and the remote such as the model number, but generally, this is the procedure:
- Find codes for each device
- Press and "HOLD" CODE SEARCH.
- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes, proceed to the next step.
- Enter the three digit code from the TV, VCR or Cable Box code lists.
- Release CODE SEARCH.
- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
If that does not work, please reply with the model number.
