Got two of them with the starter but one quit working.
SOURCE: REMOTE STARTER NOT WORKING COMPLETELY
Here is page 2 of the owners manual, Hope it helps.
This will not start the vehicle if any one of the following situations exists;
The vehicle's hood lid is opened.
The gear shift selector is not in Park.
The brake pedal is depressed.
The safety control switch is in the Off position.
1. To start the vehicle, press and release the transmitter button two times within 2
seconds. The vehicle will start and remain running for the pre-programmed 5,10,15,20 minute run cycle. As a visual indication, the parking lights will flash or remain on depending on the setting by your installation center.
2. When you arrive at the vehicle, turn the ignition key to the ON position (not the spring loaded start position), then step on the brake pedal to disengage the remote starter. The
vehicle will continue to run, but now on it's own power.
NOTE: The engine will stop running before the pre-programmed run cycle has expired if you perform any one of the following functions;
-Press and the button on the keychain transmitter two times within 2 seconds.
-Depress the brake pedal.
-Open the vehicle's hood
-Place the unit in the safety control disabled mode.
PRLED SAFETY CONTROL SWITCH
The Push-Button LED control switch allows you to temporarily disable the remote starting function of the system. This recommended whenever the vehicle is being serviced. To place the system in the service mode:
1) With the system disarmed/unlocked, and the ignition switch off Press and Hold the PRLED on.
2) Turn the ignition switch on, off, on, off, on, off.
3) The LED begins to flash two short flashes followed by one long flashes and continues this pattern until returned to normal mode of operation. This puts the unit into the R/S Override mode indicating that the remote start is in the service mode and will not start from RF or any other input Posse or otherwise.
To Exit R/S Override Mode
1) With the system disarmed, Press and Hold the PRLED on.
3) The LED turns off indicating that the R/S unit is fully functional one again
SOURCE: ezee start remote stopped working
if you have the manuals look under transmitter programming. if not go to crimestopper.com and look under manuals and you can download one from there and follow the steps into reprogramming the transmitter.
SOURCE: need programing for ast ultra remote car starter
You turn the key off to on, off to on, off to on;
Leave key in "on" position, then push and hold the little button on the antenna on the windshield - keep holding this button down on the antenna, and you'll hear 5 chirps; then push the unlock button on your remote control (and on your other remote control if you have two), then release the button on the antenna and then turn the car off.
You should be able to lock and unlock your doors now. Then try the starter. Do a Google search, and you'll find more Ultra info including a little video how to program your key fob.
SOURCE: I need a manual for an AST 1-way FM remote
go on ebay or try downloading it at www.piratebay.org and if you do find it you have to download bitlord DONT download the pro version though becuase it will say do you want to buy and u dnt want to do dat u want free things lol . well try anyway and let me no if u have done well
SOURCE: I need to reprogram my car starter..where can I
Manual link found at the top right of the page: http://www.scytek.net/astra.php?pic=images/products/astra/a1000RS.png
