SOURCE: crimestopper keyless entry remote wont unlock or lock anymore changed battery still wont work
need to program a new remote to keyless entry system it is crimestoppper cs835 rke
SOURCE: I have a Crimestopper rs-3. I have had 2 instances
What type of vehicle is it installed in? Does it crank with the key and not start or does it not do anything? There could be several problems, ie. if a bypass was used to bypass a factory anti theft it could be malfunctioning, if your crimestopper has security features enabled that could prevent it from starting even with the key. (This is most likely if the driver was able to start it by pressing the valet switch). Or there could be a loose connection in the ignition harness. Either way, I would highly recommend taking back to where it was installed and heve them go over it.
Hope this helps.
SOURCE: Hi: I have a crimestopper
Most valet switches are just a simple normally-open momentary push button like this:
http://www.radioshack.com/product/index.jsp?productId=2062508
