Cozy (W352E) Heater Logo
Posted on Jan 04, 2009
Pilot light whistles
I have a dual sided water heater and the pilot light whistles. How can I make it stop?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
292
Points
0
Get the pilot light changed. Its the only way to stop it, there is a blockage in it and you cant get in the pilot lights to remove them
2answers
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Cant get pilot to light
Brand, model, and type of heater appears on label on side of unit
For tank-type gas, under 60,000 BTU, then clean air intake. This procedure varies by brand of water heater.
Add a comment with missing information for additional help.
Also copy following link for troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I have smoth's hot water tank. problem is pilot lite is off. how do u turn it on?
You have tank-type gas water heater with standing pilot light.
Instructions for lighting pilot light are usually on front of water heater.
Since water heaters vary widely, if you want specific information without guessing, then add a comment with model number that appears on label on side of tank, and also describe the gas control valve on front of unit.
This information will let expert located manual and look up specific information plus troubleshoot steps for that model.
We have a plumbing technician to repaire the water leakage out side of our house, which need to turn off the water supply to our house. After that, we found that hotwater will not turn on (burner light...
You have gas water heater.
Probably a tank-type gas water heater.
The plumber can fix water heater.
If you want to fix water heater yourself, then more information is needed to narrow down scope of answer.
1) Add a comment for possible help.
Instructions for lighting the water heater appear on front of water heater. Do those instructions include lighting the pilot light?
Will the pilot light stay lit?
On side of tank is a label. Label shows Brand, type (LP or NG), and model number.
This information can help narrow the type of gas control valve, and point direction for troubleshoot.
Add a comment with this information for possible help.
2) Do-it-yourself: Open following link for do-it-yourself resources to help solve gas water heater problems:
Generally the instructions show how to clean water heater parts, check venting, and show different types of gas controls, plus links for pilot light problems and cleaning air intake.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
2answers
Cover not sealed would that make polot keep going out
General causes for pilot going out: downward draft of air from outdoors, back-venting of furnace into water heater vent, bad thermocouple, or burner parts need cleaning, or bad gas control valve, or air in gas line.
Water heater in attic: hot attic conditions stop natural flow of vent gas upward.
Open following link for troubleshoot resources and cleaning illustrations and instructions:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Check venting by lighting a match under the vent hood and see if smoke drafts immediately upward.
My heater is not getting hot i can not tell if their is a pilot light or a reset button i don know what to do with the heater it is very different how can i heat my water heater
Reliance makes gas and electric water heaters.
http://www.reliancewaterheaters.com/
Best way to start is to look at label on side of tank.
Label has serial number, model number, plus it will say if heater is gas or electric.
Reliance water heater age is shown in serial number: first digit is letter, second two digits are numbers: for example numbers 02 would be the year 2002.
If water heater is 8-12 years old, it might be time to consider new tank.
Gas water heater has 3 inch metal flue pipe coming out of top of tank.
Gas pilot is probably off.
Relight pilot light: Most gas water heaters today have instructions on side of tank just above gas valve that say how to relight pilot light. Instructions vary by model.
If you have gas water heater that is older, it might be easier to call a plumber.
Electric water heater has panels on front.
Open top panel and push in red reset button.
If you have electric water heater of any age, you can usually fix it yourself same day:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
1helpful
Our pilot light does not stay on...sometimes when temperature changes out side
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out as the outside air cools.
Bradford white 15 yr old power vent runs constant
pilot light will stay on if it is a standing pilot. Turn water heater aqustat down and plug back in. you probably need to clean water heater or replace it. i have drained down a couple of them and took out gas valve and cleaned and put back in worked fine. If you get me a model # i can look it up and tell you some things to try. not sure on yours if it has a different temperature control or if the gas valve is a dual control .
2answers
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Top Cozy Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
David Spradling
David Spradling
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
