My DVD player is showing the bad dis. And it won't play the dvd dis.
SOURCE: GPX d2816 problem
hey i know what it is ...i had the same problem and i took the top off and found the whole carriage for the disc inside has slotted holes and is adjustable.i simply moved it around until it worked then tightened it into place. hope that helps...... good luck badsdaddy
SOURCE: my gpx dvd player model
Either the lens is dirty or the optica are starting to fail. If you can gain acces to the optical assembly, try cleaning the lens carefully using a cotton swab and alcohol. If that fails to resolve the problem and you are able to read CDs but not DVDs, the optics are failing and need to be replaced.
Dan
SOURCE: why does it read bad disk?
its the disk laser sensor is to sensetive that why it canot reads with an ordinary disk or a pirated disk or a disk that has a small scratch.
