My 2004 Hyosung GV250 needs to have the carbs synchronized. Ive done it by ear but they are just a bit off. There is only a vacume nipple on the front carburator boot but the back carb doesnt have one.
SOURCE: Need step by step how to synchronize carbs on 1982 yahama xj 1100
It doesn't really matter which make or model of bike it is, the procedure is exactly the same.
Firstly you will need a set of vacuum balance tubes - do you have those?
TRying to balance a 4 without is an exercise in futility. They are reasonably cheap for a home set.
Here is a step-by-step.
http://www.portablepct.com/fastlarry/carbbalance.htm
SOURCE: got a hyosung gv250 that wont run..just cleaned
Not sure if this is still an issue as it's an old post but have you tried checking for a spark?
SOURCE: MY 1984 GL1200 HONDA .NEED TO KNOW WHAT ORDER I
The right side rear carburetor has no adjustment. Keep adjusting your idle to 1000 pm. Synchronize the to right carburetors to each other. Synchronize the two left carburetors to each other . Then synchronize the left bank to the right bank. You may have to do it more than once. Be sure to keep adjusting the idle back to 1000 rpm.
SOURCE: 82 gs 550 two nipples on petcock and one nipple on
is there one bigger then the other on the nipples. If so the one bigger is for the carb fuel and the little one should run down the left carb, betewwn the front of the carb and the carb mount.
SOURCE: I would like to know
Hello to every one, see how you guys can help me; I have an intruder vs800/96, and couldn't ride it like 4 years a go, 'cause it is overseas I can't no travel to offten,last time I started but engine runs for only 10 to 15 seconds acellerate then shut off and thats it after that the engine just crank but not runs. Also I notice that the breacke handle just move free back and fore with no presure;now the mechanics doesn't what to touched cause they don't feell capable to handle.Now I want to learn what I have to do so I will on my next trip and enjoy the ride. PLEASE DIRECTED ME TO WHAT TO DO .
Thank you so much
