The froth dispenser is very clean but the milk has a hard time coming out and a message comes up to clean which I have done many times what can I do next
Sounds like the venturi tube could be blocked. My model is a CVA 4085
and I can take the assembly out that sucks in the milk, mixes the air
and stem and spits out frothed milk. If yours is similar, see if you can
can reach the top of the milk outlet tube and rotate the ring around it
anti-clockwise (if you were looking up from the bottom) and take the
whole assembly out. If you have never taken this out, disassembled it
and rinsed everything out thoroughly under a running tap now is a good
time to do it. Then check the venturi tube: the clear (ish) bendy
plastic tube that that points up and has a cone with a hole in the top.
If that hole is blocked you won't get very good froth. If you can't
clear it with warm running water then VERY CAREFULLY use a small needle
to push through the hole at the top, then put everything back together.
Good luck.
SOURCE: Lack of pressure from the steam wand used for frothing the milk.
Hello Juneyjune,
These coffee systems have a series of small rubber 'O' rings that tend to crack from condensation over time causing your low pressure problem.
The 'O' rings are connected to a heater that looks like a horse shoe mounted in back of the grinding unit.
I would recommend contacting Miele technical services. They can have a technician come out to replace the 'O' rings or you can order them from the technical services rep if you know someone that can replace them for you. Just be careful. These machines operate off of 220 volts and that is no fun to get shocked by. I have been many times with this machine
Good luck!!!
SOURCE: my miele cva 4075
Hello Loriktarrant,
I understand the your Meile CVA4075 is showing you an F73 code. This code means that the brew unit needs to be cleaned. Here is a link to the owners manual on page 40 it shows you how to manually remove and clean the brew unit. The other issue you are having with the milk and coffe not being hot enough could be to the machine needing descaled.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man enter the numbers in the box and click download.
Thank you for choosing FixYa.com
Justin
