Oven comes on if you let sit with power unplugged but will not work but one time unless you leave unplugged like overnite
Is it the oven or the stove top
what make ie ge ,lg??
how old?
does it use elements or ??
on those types there is a fuse panel cover using old round screw in fuses if a newer one may use fuses similar to car fuses one is iether not tight enough or improper contanct possible grease or oils from cooking
if screw in type check for tightness if tight lossen and remove on bottom is a brass strip gentle pry out a little bit only about a 16th of inch on wipe down with rubbimg alcohol for clean contact
check inside also but turn off power to oven before cleaning these
oven thermador
