SOURCE: Dymo LabelManager 300
I would suggest reinstalling the driver.
First disconnect the label writer, then go to :
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Scroll down and you will see your model number and download the drivers. Then run the installation again and it should prompt you to connect the label writer, which should fix the problem
If not also try reinstalling the "Label Software Application" listed on the same page as well.
SOURCE: Cannot get dymo to print vertically
On mine you use the FORMAT button
Then theUP arrow until you see STYLE
Then press OK
Now press the UP arrow until you see VERTICAL
Now press OK
SOURCE: How do I change the
Hello, Changing the Font Six font are available for your labels: Arial Narrow, Arial Normal, Arial Wide, Times New Roman, One Stroke and Frankfurter. When you specify a font size, that size applies to all characters on current page. To set the font 1. Press the Font key. 2. Use the arrow keys to move to the desired
Please follow this instructions
font and then press OK.
Also here the link to the manual for further instructions.
http://global.dymo.com/img/compel/Q5S_A-MZSgeJZGJ73tJmbPunig_yx_v1.pdf
regards
