Key remote stopped working with very intermittant flashing. I changed the battery and now it is constantly flashing and still does not work. The key on its own will open the doors and start the car.
SOURCE: Audi A6 alarm
I believe you can find a help by visiting this site
www.audiusa.com/audi/us/en2/experience/Owners/Audi_Authorized_Collision_Repair_Center/Audi_Authorized_Collision_Repair_Facility_Program.html
Hope my info helps you,
Thanx for using fixya,
Good Luck.
SOURCE: Key fob on my audi a3 1998 has stopped working
You need to get the key re-programmed by Audi. Same thing happened with my A4.
SOURCE: remote central locking not working
As far as the central locking issue, it sounds like you need to replace your central locking pump. You can buy them online.
I have a 95 A6 and I am in the process of looking for a new central locking pump.
The part number may be 4A0 862 257 J, that is what it is for me.
There are directions online as to how to change this yourself once you get the part. If you buy from the dealership the part is $500.
Be thankful your child locks weren't engaged. We haven't been able to open our back doors since the pump went out.
SOURCE: Audi A6 Anti Theft Central Locking Tantrums
Sounds like you are having problems with your built-in alarm system. Like most systems in your Audi, you can read the error codes stored in the controllers. It takes a tool normally only a dealer has (VW or Audi) or an adapter like the VAG Com. (Google it)
I also think you can disable the alarm system and just use the key.
Could the lock button on your remote be stuck? Use a different key/remote. (leaving the suspect key at home.) The keys/remotes can be taken apart....
SOURCE: central locking will not work on remote key.
unlock car with key/hold over for 30 secs then lock car with key/hold over for 30 secs then unlock with remote hold button down for 30 secs.this should reset system.
