A WKE 8000 IS PROBABLY THE EASIEST UNIT TO REPLACE THE BOARD ON, REMOVE THE TOP FRONT GRILL(COLD AIR DISCHARGE) AND BOARD WILL BE RIGHT THERE BEHIND THE GRILL, USE NEEDLE NOSE PLIERS TO REMOVE WIRES FROM BOARD, MAKE SURE YOU MARK THE WIRES BEFORE YOU DISCONNECT THEM(USE BLUE TAPE WITH NUMBERS) AND TAKE A PHOTO WITH YOUR PHONE OF THE WIRES WITH THE NUMBERS ON THEM,ONCE WIRES ARE REMOVED PULL THE OLD BOARD UP AWAY FROM THE 6 PLASTIC PEGS IT IS SITTING ON AND INSTALL THE NEW WKE CONTROL BOARD(IT SHOLUD BE BLUE IN COLOR) PRESS IT ON THE PLASTIC PEGS, AND RECONNECT THE WIRES USING THE NUMBERS AS GUIDE
SOURCE: I need a wiring diagram for a Breezaire WKE 8000
THE MANUFACTURER WILL PROVIDE YOU WITH A DIAGRAM OF THE CONECTIONS FROM THE CONTROL BOARD TO ALL THE COMPONENTS THE BOARD CONTROLLS.
MIGHT HAVE TO INSIST ON THE REST OF THE DIAGRAM SPECS BUT THEY WIL PROVIDE THEM TO YOU
858-566-7473 BREEZAIRES NUMBER
