The right side comes on and works great but the left side will not come on. Is there a fuse somewhere?
SOURCE: wells 35lbs fryer double vat
Hello
This sounds to me as if your thermostat is not cycling the unit off. But I can see a second problem as well there should be a high limit cutoff to prevent it from running on and boiling over. I would check both. The thermostat is the dial or knob to regulate temperature and the high limit is the safty to prevent boil over or run on.
Thanks
