Question about Wells F-49 21148 Deep Fryer
Fryer not heating up and both lights (temp light and reset light is on. have 240 power coming out of the wall. The heating element does heat some, but not enough to heat the oil. Could it be a bad element or perhaps a thermostat?
Posted by terry_harden on
renegade-35
    Master:
    Sergeant:
  • 492 Answers
Thermostat
Posted on Jan 24, 2011
Gaggenau fryer won't heat
check to see if there is some kind of breaker on the unit, it should be like a reset button. some kind of safety switch has tripped, you need to find out what and where it is.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Nov 19, 2007 | Kitchen Appliances - Others
Tip
Will not power on, powers off, will not heat Pwr light out or goes out.
Like most of the problems listed on FixYa about this Deep Fryer ours worked fine the last time we used it, but we could not get the power light to come on again. I found that there is s SAFETY Micro-switch on the heating element control unit. This switch prevents the heating element from being turned on when it is not in the Fryer Pan. The accuator lever for the switch is located under the guide slides on the heating element control unit. It is a metal lever which is moved as you mount the heating element control unit on the fryer pan. You have to look closely under one of the guide ledges on the heating control unit to see it . The problem is that over time the adjustment of the lever changes as it flexes under use. I simply readjusted the lever by forming it with a pair of long-nosed pliers. CAUTION !!!!!!! You can bend the lever so far that the switch is closed all the time defeating the Safety Switch and create a hazard in that the unit will heat as soon as you plug it in whether inserted in the Fryer Pan or lying out on any surface. This might burn someone or cause a fire. Good Luck
X-IBM
on Oct 09, 2008 | GE 168997 Deep Fryer
I have a Butterball indoor turkey fryer that lost power and the red light went off, is there a reset button on the fryer
There is a thermal cutoff near the heating element just like all appliances that make heat. It's supposed to stop a house fire but makes these appliance companies a lot of money.
Nov 28, 2013 | Masterbuilt Butterball Professional Series...
Power light heat
The heating element could have failed
Oct 11, 2013 | Presto 6-Cup CoolDaddy Elite Deep Fryer
I have a tefal family pro fryer, when i switch it on the green light comes on instead of the red and it will not heat up. why?
Look for a reset button on the unit, Push it, you will hear a "click' then the unit will work. If not, there is an electrical problem, the element, or temp control is bad.
Apr 11, 2010 | Tefal FR4008002 Pro Fry Deep Fryer
My Frymaster is beeping and coming up with a message HOT on the screen
Temp got to hot and shut down high limit. Also check for a broken wire to high limit
Sep 17, 2009 | Frymaster Dean H22 Deep Fryer
Deep Frier power indicator light is on but will
Most fryers have what is called a hi limit. When the oil temp reaches a certain Max temp this switch opens the circuit and will not allow the unit to heat. On commercial fryers, the hi limit has a really small red plunger button. Push it in to reset.
Mar 28, 2009 | Kitchen Appliances - Others
Deep Fryer Element Won't Heat Up
Look for the reset button and it should come back on. I just did and lights came on immediately.
Nov 06, 2007 | Rival CZF625 Deep Fryer
Wells F-49 21148 Deep Fryer Logo
471 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
ray gallant
Stan Ford
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
