I have a yepo yp 757f, i tryed to upgrade it but upgraded it with wrong files and i didnt back up my old files and now the screen is just blank and doesnt do anything HELP PLEASE
I've a busted MP4 of the exact model but I'm looking for the firmware, can you tell me where did you get yours? I've a busted MP4 of the exact model but I'm looking for the firmware, can you tell me where did you get yours?
AnonymousMar 14, 2014
no powerno power
You can't post conmments that contain an email address.
try removing all of the other info from the listing, except for the album, artist, and title. This is strange, but if you could tell me what brand it is, then it could be something much simpler.
Select the Downloads tab and next Firmware.
Under Description look for the word Games. For Win XP / Vista there's
a zip file available (firmware at least upgraded to version 5.08).
Download the zip file "20080717110554593_Games_worldwide.zip":
right click on the file and
next select "Save target as..."
How to upgrade / reinstall the firmware upgrade, go to next link: http://downloadcenter.samsung.com/content/FM/200905/20090507111626062/SW_Upgrade_instruction.pdf
Upgrade Methods
If the product does not power on and shows any of the following symptoms, you may try the upgrade methods
in this chapter without having to disassemble the product:
- The product does not turn on when the power switch is pressed.
- The product powers on normally but no USB connection can be made.
- The product’s icons appear garbled or malfunction.
- Files are corrupted, or the product shows as a “removable storage” in Windows but cannot be accessed.
Firmware Upgrade Method
1. Download the firmware upgrade file to a folder and decompress it.
2. Check the contents of the folder that was decompressed.
3. Connect the YP-T10 to the PC.
4. Open the Removable Disk folder of the YP-T10.
5. Select the installation file in the folder that was decompressed,
and then copy the upgrade files to the Removable Disk folder
of the YP-T10.
6. Perform “Safely Remove Hardware”, and then disconnect the
device from the PC.
7. When power on YP-T10, power off after
“Image Upgrading...”, “AUI Upgrading...”
8. Power on again. After “Font Upgrading...”,
“Image Upgrading...”, “AUI Upgrading...” set will be power
off.
9. After the upgrade, go to “Menu” → “ettings”→ “ystem”→
“Firmware” and check the version.
If the battery power is low, the upgrade will not start. In this
case, you need to connect a USB or charging cord for the
upgrade to start.
I would go ahead and do the firmware upgrade from Samsung's website - make sure you enter in your EXACT model # - including the part after the YP-T10. The RSC (resource) files need updating, and I can't think of a better way to do that than to upgrade the firmware. There is a small possibility that you have files on there with expired DRM licenses, but I would try firmware upgrade first.
1. try formatting the player again 2. try upgrading the firmware again
if no luck then it will have to be returned for fixing. There are warnings about not completing the upgrade process. Don't mention the above when returning it for repair under warranty.
no power
