Sony Ericsson W300 Cellular Phone Logo
Anonymous Posted on Dec 29, 2008
W300i my w300i keep going off and on every 2 minutes. help me....
  • Anonymous Dec 29, 2008
    yes i used multiple batteries but still keeps turning off and on every 2 minutes.
SALMAN NASEER
Level 3:
Genius:
  • Master 1,011 Answers
  • Posted on Dec 29, 2008
SALMAN NASEER
Master
Level 3:
Genius:
Answers
1011
Questions
Helped
309643
Points
3022
Dear,
it can be defactive battery problem. did u try by changing new battery.
if not, do it by the way.
or if it not the issue then tell me that this problem comes automatically or when u open its flip to get viewed inside.
i had it and was facing white screen problem then critically invisible display. finally, i got strip problem becoz this kind of phones have it.
regards,
1helpful
When download game and other application for sony ericsson w300i in this display operation failed please help me
when download game and other application for sony ericsson w300i in this display operation failed please help me
Oct 21, 2010 • Cell Phones
1helpful
Can i use my 3 sim in an orange W300i
get a new set....jokes apart
as it is washed out fully you need to put it in front of hair dryer for a while and do it for some time if still it is not working
then
get it repaired from your local service center they will definitely give you the solution
Sonyericsson w300i
Remove the battery for 5 minutes..put on your battery and then use the samecode...the default code 00000
Sony ericsson w300i phone (text messaging)
BLU - contact your mobile service provider for more assistance on this matter.......
JAMIE - try master resetting all, or take the phone into your carrier and have them check the settings
2helpful
2answers
W300i phone displays white screen
Try taking out the battery overnight and replace and try to turn on. If this doesn't help, then try updating your phone's firmware.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w300i?cc=gb&lc=en
2answers
Help w300i no sound, will vibrate only Thanx W300I ONLY VIBRATES PHONE NOT ON SILENT. CAN LISTEN TO MP3 PLAYER THROUGH EARPHONES AS WELL AS HEAR SOUNDS SUCH AS OPEN PHONE
Opened the phone, 4 screw. 2 at the base of the battery hatch, 2 under the speaker cover. Check the contacts between the speaker and the phone's motherboard. Adjusted the contacts and the phone now works
Re:photos
go to http://www.sonyericsson.com/cws/support/products/w300i?cc=us&lc=en and click on software downloads. select the application that you needed for your photos. if you can't find the application, just provide me the complete name of that application/software so i can further look for it
My sonyericsson w300i bluetooth and text massage not working need help programming setting
U just need to do the following steps:-
(1)- go to the menu
(2)- Select settings
(3)- select master reset in the first columns last
(4)- enter the code.
And if it doesn't work u must get its software updated from sony ericson service centre
Internal antenna loose
Dear bubbapld Please download the part lists of the w300i at the following link www.laneros.com/attachment.php?attachmentid=109156&d=1185393994 Go to page 11. You can see the placement and orientation of the antenna clearly and then you can put it back together. TIP: The gold round pad must go to the left of the phone and be visible to you. This is where the tip of the antenna pin at the motherboard will touch. Regards
2answers
W300i Transfer Error
Unplug phone from any connections. Remove battery, Keep power button pressed for 30 seconds. Insert battery, Turn on phone.
Sep 27, 2007 • Cell Phones
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
