Need to replace speedometer cable on 1993 Ford F250 XLT 4X4. Need to know location of speedometer sending unit.
SOURCE: thermostat
U should be able to locate it by following the upper radiator hose to the engine, where the hose is clamped to a housing . The thermostat is in the housing, which is usually secured w/ 2 bolts. If this doesn't help, let me know.
SOURCE: Location of Speed Sensor 1998 Ford Explorer XLT
polarcycle is right but there is a speed sensor on the drivers side top of the trans. toward the tail shaft or transfer case. there is as well a sensor inside the trans. itself that is mounted on the web. behind the overdrive band and drum.
SOURCE: 1999 f250 door lock relay location
it should be in the fuse box either the one under the hood or the one in the cab
SOURCE: horn not working on a 2006 ford f250 xlt
The cause of this is not the horn or fuse in most cases, it is caused by the rotating contact that connects the horn button, in order to repair this you will need a new clock-spring contact, to install the airbag must be disarmed, his has to be done by the book or serious injury can result.
SOURCE: REPLACING LOWER BALL JOINTS ON 2000 FORD F250 4X4 7.3L DIESEL
hello,yes you do have to take the hub off to replace the ball joint with the ball joint being on the back side of the hub. hope this helps and please rate this.
For
speedometer related issues, the help links are provided below. Click the link
below to go through its details: ----
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
why speedometer not working?
http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working?
http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html
Speedometer runs backward?
http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
Warning lights on and
speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.html
ABS & Brake lights
warning indicator steady on dash and speedometer not working?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not
reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works
intermittently?
http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
How odometer works in cars?
http://technoanswers.blogspot.com/2011/11/how-odometer-works-in-cars.html
Speedometer not working on Ford?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
This will help.
Thanks
