RCA 32F531T 32" TV Logo
Posted on Sep 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have sound but no picture on my rca 32f531t
My rca 32F531T power and there is sound but no display does any know where i can get the schematic for this tv chassi # itc008gww
Glen Ingalsbe
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 16 Answers
  • Posted on Nov 02, 2019
Glen Ingalsbe
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
16
Questions
Helped
9271
Points
68
First make sure the filament is lit on the CRT. Just look in the neck of the picture tube. If lit, then verify if you have Hi-Voltage on the picture tube. When the set powers up is there a sound like rustling leaves, if you hear this it usually means you have Hi-Voltage. You can also hold your hand up to the front of the glass to check for any static electricity. If present, you could still have a missing screen or grid voltage on the CRT or you may have some kind of video problem. If you have no feeling of static or rustling leaves sound then the horizontal drive signal may be missing to the horizontal output transistor. At this point you will need the services of a competent TV service tech.
Note: Horizontal output transistors usually don't open, they short. When they do they will blow a fuse and you will NOT have either sound or picture, just a dead set condition. The hi-voltage D.C. from the main input power supply is filtered and regulated down from approximately +170volts to +130volts plus or minus some depending on the model and screen size of the set. It then goes through one end of the main hi-voltage winding of the flyback transformer and then to the collector of the horizontal output transistor.
Anonymous
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • RCA Master 5,807 Answers
  • Posted on Sep 29, 2012
Anonymous
RCA Master
Level 3:
Answers
5807
Questions
0
Helped
272293
Points
13914
You can have these guide:
Flyback Transformer
the horizontal output transistor is for ITC008
search these site you can find more info for your chassis
that was 2 years ago
5 Related Answers
Vista Electronics
  • 1694 Answers
  • Posted on Oct 02, 2007
SOURCE: RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Anonymous
  • 579 Answers
  • Posted on Jan 03, 2008
SOURCE: ..sounds like it is clicking on and off..on and off..etc.
How old is this TV?
Sounds like it has high voltage failure.
(If you hold your hand on the screen when you try and turn it on, do you feel the static? )
Unless the set is over 10 years old, I would overhaul the high voltage circuit. Should cost under $200 at a shop.
A
Anonymous
  • Posted on Mar 22, 2008
SOURCE: Part numbers
look above for answers /cz is .22mfd/16v cap and rz11 is a 15k -ohm resistor/st.
ismash55
  • 138 Answers
  • Posted on Jul 26, 2009
SOURCE: Plzzz help me!!!!!
Your defective has defective parts on horizontal section. You need to bring the tv to expert technician,
gopakumarg43
  • 76851 Answers
  • Posted on Jun 03, 2011
SOURCE: I need to know the
Hello
The number of horizontal output transistor is [TL 035]. If this number is not available, you can use exact substitute after reffering it to transistor data book and equivalents. OK.
How to unlock RCA 32F531T 32 '' tv. I tried the manual solution but didn't work.
You might have to enter its service mode option to unlock it. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 580 posts to different brand TVs.
2helpful
I need to know the datasheet for the horizontal's transistor for a tv RCA 32F531T, because I lost the replacement
Hello
Plzzz help me!!!!!
RCA F32650 no picture
Sounds like the flyback. Mine did the same. I am in the process of trying to fix it. Try techlore.com for more help.
Cpu
central processing unit,cpu are all driver of tv like sound,picture,switches malfunction and etc.
Sound but no Picture
the horizontal section is not firing up to generate high voltage to produce a raser,requires service possible shorted output transistor,not pricy
How old is this TV?
Rca direct view tv 36" f36665
clicking,w/no sound or pix is usually IHVT, AKA flyback transformer.Please clarify size and model #. Include last three characters in Thomson products service #---Ex.=F36665-YX01.
2answers
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
