The pass key code was on all day then finally the van shut down and wouldnt start anymore now i cant the fuel pump to come on i ran my own jumper wire and the pump came on but the van still wont start im not gettin any fuel to the motor i have tried everything to reset the security system
SOURCE: 98 chevy camaro wont start how do you reset fuel pump regulator ran out of gas
BLEED INJECTOR SYSTEM NOT GETTING FUEL TO ENGINE TOP.
SOURCE: vehicle just keeps cranking wont start.
Make sure that your fuel presure is up to at least 60 psi if not that could be your problem. If not, make sure you are getting spark, if not could be your Crank sensor or ingniton module ECM. Usually if your Engine control module wouldn't be bad because of your fuel pump is working, but may not be putting out the proper pressure for the fuel system. Fuel Pumps are a Problem with that year..
SOURCE: how do reset the security system on a 2002 chevy
Good morning, I am having a problem starting my 2000 chevy venture. I believe its the security system acting up, can anyone tell me how to reset the vechile's security system?
SOURCE: need wiring diagram for 2001 kia sportage , need it for fuel pump
my 2003 kia sportage xse speedo stopped, rev counter still works. anyone got any idea
