Greetings,I own a Sharp XL-MP130 Micro Cpmponent System. When I loaded a couple CDs, I noticed they would not play nor would the trays eject. I opened the system up and finally got the CDs out and put it all back together with no problems, I went to open the trays again without the CDs and still they would not eject. I do believe the CD unit has gone bad and was wondering where I could acquire the CD changer unit without throwing the entire unit out. I do not want to send it for repair due to the fact of the cost invovled. If I were to just get the CD changer unit, I would be fine. Amy assistance would be greatly appreciated. Merry Christmas and Blessed New Year
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
SOURCE: CD player fails to read CDs
Hi Everyone !
We got the same problem two month ago and we fix it. The problem is drying lubricate oil from elector motor which spin the cd disk. You need to open top cover its 5 screw , 4 an sides and 1 on back. Then you see black cd changer in side. You need to open top cover of cd changer by unlock plastic clips and slide cover. Under cd holder you can fined elector motor that spin cd. You just need two drops of lubricate oil on top bearing at electromotor. My works fine right now .
Good luck.
SOURCE: 5 cd with cds in it won't open
Undo the screws and take the cover of you'll be able to take them out ... But only if you don't have a warranty if u have the take it to the place where u bought it from
